barryg41, I found that feature in the instruction book. It was set at . 4 (seconds?). I re-set it to 2. 0 and it seems to be better.
BarryG, I agree with what you said about fooling with the sender line and then the guage working ok for a few weeks. I made up a "plug" out of 5/16th aluminum round stock and drilled a . 035" hole through it to make a restrictor. It seemed to help for a while but then as you found with your guage, it started to "roam". Try what barryg41 (are you two related?) said to do. This feature is a time delay in the guage as to how often it takes a reading from the sender. I am going to try a smaller restrictor in the line also. I have always noticed that pressure sending units have a very small bore hole.
