I have Briar Hoppers test gauge and had been checking my pressures at the access port off the VP44. these were 3WOT, 13 at idle. I told my local dealer this so he replaced the lift pump no questions asked. After I got it back the pressures hadn't changed then it started starting hard.
This morning I checked both before the filter and at the VP44. Pre filter it never goes below 8 psi. After it goes to 3 still. Does this mean I have a clogged filter and could that be the reason that the truck starts hard after sitting awhile.
Two months ago I also put in new dd2's. The hard starting problem started about two weeks after the lift pump was put in and a month after the injectors were installed.
Sorry about the length of this post, I took it to the dealer were they had it for a week and a half to fix the hard starting (replaced the fuel lines) I don't want to take it back if I can help it.
