Fuel Pump Install Questions
Muffler elimination kit from Geno's
Tail pipe diamameter
I have a mallory fuel pump on the way and I was just wanting to get a push in the right direction with the install. Do you have to drop the tank when you install and also do you have to remove the lift pump that's on the tank already. I've been driving the truck with the fuel light on for a couple days now, trying to get it as empty as possible without running out of fuel. Also, what wire do you tap the hot lead from the pump into? I would think that it would need to be something that it inline with the ignition but who knows what wire that could be?!? This install should be a lot of fun. Keep your fingers crossed.
2001 ETH SWB Black Sport, Blue Box, HX-40, 4" Exhaust, DD III's, RE-0880, ATS Manifold, Muth Signal Mirrors (way cool!) Too MUCH Stereo, Clifford Avant-Guard 4 w/ Remote Start, 2" leveling kit, Grizzly Nerf Bars, Pathfinder 315's, Ram Grill Guard, BLACK magic hellas, Dual firesticks, and one loud, annoying PA
Mike's right. Cut the old wires off the lift pump, there's only two, extend them if you plan to move the lift pump closer to the tank (the ideal location) and install the wires on the new pump. Now you can plug it in like the old one.
blk----- get in touch with hvac on his progress, he has already been there done that
B
END THE OPPRESSION FREE HVAC NOW
Demon,
There is no pump at all in the fuel tank. Your factory lift pump is bolted to the engine block just behind the fuel filter housing. Where ever you decide to mount the new lift pump,you should be able to use the stock wiring.
-Mike
BLKDEMON... just sent you an e-mail with a pic. , hope it helps.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Look on the 24 valve forum search for mallory 4150 or BG220. I went through the whole ordeal a few weekends ago and posted all the info needed. Hope it helps, and good luck.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, race transmission, Barry Grant fuel system, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
