2nd Gen Non-Engine/Transmission Fuel pump
I am looking for a fuel pump to pump some old fuel out of an older Delta fuel tank I just got a couple of weeks ago. I was thinking about a cheap Carter fuel pump. What would you guys use. I need the pump to run off a battery and have at least 3/8 or 1/2 fuel line ports. Any info would be great. Thanks.
Thanks guys, I found a cheap pump at Napa. I was able to get the old fuel and water out of the tank. It is a 12 volt pump I just ran off of a battery. now I just have to figure out how to get 2 pieces of PVC pipe out of the tank. I did not know these were in there till I got the tank home. I bought some long reach fingers and have yet to be able to get the pipes out. My next step is to maybe cut a hole in the tank on top where the DATA plate is at and reach in and pull the pipes out. I hope I don't have to do this.
