TC, I didn't mean to offend you, and I see you have offered and helped many members on TDR over the years.
That being said, I think I can safely say I have attended more Cummins diesel factory training than anyone on this forum. I have gained the knowledge of the operation of Cummins engine and fuel systems from some of the best Chrysler and Cummins instructors and engineers. I back up my information with factory service information.
So when I see something that goes against the things I have learned personally from Cummins and Chrysler I make my best effort to provide the members here with factual information that is available to those Dealer professionals that repair the Cummins we all love.
At times we may not agree, but that does not mean I discount all the things you have done for the good of the other members here. It is up to them to decide what information is correct for their situation, but me sitting back and ignoring posts that do not make sense to what I have leaned over my 32 years in this business is also a disservice to them.
And while I'm at it, this first section is straight from the Chrysler student training manual concerning the PLV. The second section is straight from the factory service information (2006 MY) for the proper testing of the PLV.
Figure 34 Fuel Rail Pressure Limiting Valve
The fuel rail pressure limiting valve uses a knife-edge seal and is threaded into the front of the
common rail. It is a dual stage, mechanical relief valve. The first stage relieves fuel rail pressure if
pressure exceeds 1,950 bar (28,282 psi). The second stage of the valve maintains pressure at 900
bar (13,053 psi).
The PCM can detect a fuel limiting event based on data from the fuel rail pressure sensor. The PCM
counts any fuel limiting events that occur and stores the data in memory. The wiTECH™ can display
the PCM fuel limiting counter data.
The valve can be replaced, but it must be inspected for leaks under operating pressures.
PRESSURE LIMITING VALVE
1. Using the scan tool, measure the rail pressure and determine if the rail pressure is excessive (above 185,000 kpa/26,831 psi), if it is, troubleshoot for excessive rail pressure first.
2. Remove the banjo bolt from the pressure-limiting valve on the fuel rail.
3. Install fuel system test fitting ( 9013 ) into the pressure-limiting valve.
4. Attach one end of a fuel hose to the fuel fitting and put the other end of the fuel hose into a container.
5. Perform the tests listed below to determine if the pressure-limiting valve is leaking.
6. a. Operate the engine at idle and watch for fuel flow into the fuel container.
7. b. Operate the engine at idle and actuate the high pressure safety valve test with the scan tool. Watch for fuel flow into the fuel container.
8. If fuel flows into the fuel container, replace the pressure-limiting valve. If fuel does not leak from the pressure-limiting valve, the test is complete.
9. NOTE: do not drive the vehicle with any portion of this test kit installed.
The photo I posted that was removed earlier tonight showed this procedure being performed in an actual Chrysler training class. I'm sorry if you disagree with the factory diagnostic information, but I feel compelled to provide the members here with the information the engineers that designed it determined was the proper repair information.
