HTML:sometimes the threads on the screw suffer when the collar is removed and you can get a false bottom. Are the stock fuel screws all the same legnth?
That makes sense about the threads. .
I'm betting the screws are the same length.![]()
One would think the screws should be the same length but... ... ...
There is a noticeable difference between bottoming the screw and hitting messed up threads. The case threads are a lot softer and little pieces will come off them if you are not careful. :{
