Details here: TDR Privileges
What is the best fix for the faulty fuel sending unit in the fuel tank? I'm sick of listening to my "low fuel" alarm coming on sporadically while there is plenty of fuel. I've heard that a new one from the Dealer is still the same piece of junk.
I listened to that low fuel alarm for two years before I pulled the tank and fixed mine. I wish I had taken pictures of my fix but it was pretty simple. I welded a small arm on the bridge on the sending unit and put a small spring under it to force more pressure on the reostat arm so it didn't break contact. If you drop your tank, pull the sender and look at it it is pretty easy to figure out whats wrong and how to fix it, Good luck with your project.
I think the rest of it is all stock. Kirk's simple fix is all that he said he did to his fuel module. My fuel guage sending unit had over 200K miles on it when it failed. The new one I bought from Dodge looks to be almost the same. It does look a little bit better made in some places but not much. So far so good with it.
