I'm looking for any advise I can get for removing the fuel shut-off solenoid on my 93 VE pump. I'm aware that it's just a plastic plunger and a small spring inside of there, but I can't seem to get a wrench on there to even see what size nut it is. Has anyone opened up this part of the pump who can tell me which size wrench I need to remove it and anything else I need to remove to access it? I'm in the midst of getting rid of the factory keyed "ignition" switch (should really be called a run/start switch) and replacing it with toggles and a push-button starter switch. I assumed that the shut-off solenoid would be a little easier to remove than it is, but you know what they say... When you make assumptions, you make an a.s.s. out of U and MPTIONS.
