Let me tell you I just got through trying to figure why mine was doing the same thing. Turn the key over, but don't start the truck. Left up your solenoid and see if it will stay up. If it will your problem is in the relay. The relay for the fsd solenoid is located on the firewall close to the brake master cylinder. there will be two relays. A four blade and a five blade. if you think the five blade is bad switch it out with your horn relay located in you box beside your battery on the driver side of the motor. If that is not it, it is the four blade. I got mine from dodge for 44. 00 dollars and the truck fired right up. Hope this helps. Mine both tested out OK with the ohmeter, but was still bad.
1995 2500 4X4 Claret Red, tinted windows, tool box, diamond bed caps and tail gate cover, cb, cd and eq. and many others
NRA MEMBER
NRA MEMBER
