Archived Fuel solenoid relay
Archived Help: fuel pre-heater wires caught fire
Archived ball joint repair
HELP!!!!
Fuel solenoid will not pull in on it's own. There are two relays on the firewall next to the vacuum tank for the brakes They are side by side. A small one closer toi the center of the car and a larger one closer to the vacuum tank... . WHICH ONE GETS REPLACED FOR THE FUEL SOLENOID
PLEASSE HELP I WAS TOLD AT ONE TIME IT WAS THE SMALL ONE AND EVEN GOT A NUMBER FOR A RADIO SHSACK REPACEMENT
Solenoid still will not pull up... now my mechanic is telling me it is the LARGER RELAY WHICH ONE IS IT>
TRUCK IN SHOP RIGHT NOW
The one on the right as you face the firewall from the front is the fuel shut-off solenoid, and the one on the left is the fuel heater relay on my 1998. It is pictured at page 14-99 in my 1998 Chrysler Service Manual. Nick.
Problem solved ...THANK YOU
Thank you for your response
I was told several times that the other relay was the one so I spent a lot of time on it, I was even given the part number for a radio shack replacement supposedly for the fuel solenioid relay
But hey we all make mistakes The problem has been solved and everything works and I am buying a new relay from Dodge for $43+ tx.
The old relay is working for now.
Thanks again everyone
