I am going to bypass the factory pickup in my 03. My ? is if I make it out of 1/2" how much will the fuel be pulled away from the FASS when the truck sits? Do I need to add a one way valve to avoid air pockets? Thanks
I have often wondered why a drain valve in the bottom of tank was not engineered. Especially diesels for the fact of getting a bad tank of fuel (water).rbattelle said:You guys might want to read this thread. Csutton7 has been running a very simple gravity-feed system by simply poking a hole in the bottom of the tank and inserting a fitting. His setup appears very reliable.
And that thread is a gold mine of information from 2nd gen owners (let's face it, they're the experts on low pressure fuel systems on these trucks).
-Ryan![]()
RTillery said:I just had my tank out when I did the vent mod on my 04. I had maybe 5-6 gallons left when I dropped the big black box. When I pulled out the sending unit, hose inlet, center module fixture I found something interesting. The fuel in the tank was only about 2" deep but the center fixture was nearly full with maybe 10" of fuel. This module is about 5" in diameter and extends from the top of the tank to the bottom.
This center module has the return line in it and that must help to keep it full when your truck is running. As the tank gets low, this module must certainly be uncovered as you accelerate or decelerate due to the momentum of the fuel. This thing captures some of the fuel as it goes sloshing by, and maintains a steady stream to the pump. There is an extremely fine mesh screen on the bottom of it that acts as a prefilter for the fuel heading to the engine.
If you place a simple pickup in the tank, are you risking a setup that at some point may be out of the fuel on accell/decell? Could you be sucking air in certain driving conditions?
In many tanks there is a depression or sump in the tank that the pump or pickup is installed in to keep a reservoir of fuel surrounding it during movement of the vehicle. We do not have that in our truck tanks. It looks like Dodge engineered a method to keep the fuel pickup wet with this center module. You might want to consider that when redesigning your pickup.
