2004.5 4x4 6 speed manual
Hey everybody.
I've really learned a lot about this truck here, thanks to you guys.
This project:https://www.turbodieselregister.com/threads/preparing-for-a-pretty-big-trip.272221/ is what I'm dealing with now, but I wanted to start a new thread due to the fact that it all went down a road I didn't expect to be on.
I installed the PacBrake that was recommended, and it works as expected.
I decided against a rack of gauges that I potentially would have been wasting money upon.
Instead, I installed the BD Low fuel pressure warning light. Cheap and reliable.
I have found that the OE filter mounted lift pump has been replaced with the in-tank pump previous to my owning the truck.
So,,, after installing the alarm LED, I keyed up the pump a few times to purge the air, the light went out as expected. BUT what I didn't expect was that under normal driving conditions, driving around the neighborhood, the light comes on almost all the time. So this means I'm running under 5 psi fuel pressure all the time.
So, today I dropped the tank and ordered up a new in tank lift pump.
Now that the tank is out of the truck, I've found that there are 3 unused ports that are just open to the atmosphere. There aren't any other hoses connected, just the pressure line, the return line and the electrical connector. I intend to plug these before replacing the tank, but then I was wondering if I need a vent line?? No idea why these are there, or what they were for. Maybe it's a junkyard tank from a gas truck?
I will try to post a picture.
Any opinions and advice is welcome.
Cheers
Bert
Hey everybody.
Cheers
Bert
