I'm in the process of replacing the fuel sender, and I've run into a question. I've got the tank disconnected (fuel lines and electrical), straps are loose, but now there's a crossmember blocking lowering the tank. It's right behind the output of the transfer case, has four bolts holding it in place (between the frame rails, and those suckers are tight), and only suports the fuel tank. The factory manual makes no mention of this thing, not even in the frame section. I thought I'd be able to slide the tank enough to get it out, but that won't work. This is on a 2001. 5 Quad cab 4WD with 35 gallon tank. I've always been able to find any answers I needed on TDR, never had to post before. Didn't find any reference via search, so here's my first post. Thanks in advance for any help.
