First of all - I don't claim to be a fuel system delivery expert. At most - I'm a 'parts changer' when it comes to anything before the lift pump...
Recently, I noticed that my truck was dripping fuel - on closer inspection I found a steel feed line along the frame that was badly rusted. So, I removed 4 of the bed bolts and loosened the back two so that I could lift the bed with my cherry picker to have a look at replacing the lines from the sending unit all the way to the lift pump. The sheer number and intensity of the cuss words that followed after I saw the sending unit would impress a drunken sailor.
So - I did what anyone would do... yanked the tank and pulled the sending unit out. There really isn't much to it. Other than a float valve at the sump that prevents you from drawing the fuel tank completely dry - it isn't complicated at all. There is an auxiliary port on top that I chose to reuse as the new return - that will dump fuel into the middle of the unit just like OEM. The OEM steel feed/return lines were removed and that hole plugged off with a PVC pipe plug.
I then fabricated the piece d' resistance from hardware store copper/brass fittings. The big piece is an air chamber with a 1/2" sweat fitting - interestingly this thing necks up to 1" copper pipe... which fits PERFECTLY into the OEM rubber grommet where some kind of vent hose was. (My fuel cap vents to atmosphere - so I don't need another vent. ) The other parts are self-explanatory... I sweat them together with common plumbing silver solder and Nokorode paste flux. I was hesitant to sweat the copper to the brass hose barb fitting, but it worked out just fine. (Excessively good preparation is the key to sweating fittings!) I then took socket heated up with a propane torch to make the hole for the sump tube in the plastic... The whole thing is able to slide up/down just like OEM - to allow for the poly tank to flex, etc.
Concerns - will this setup actually work? Will the lift pump be able to draw fuel through a 1" pipe as opposed to the OEM 3/8"?
I'm going to give it a whirl after I replace all of the steel lines and the horribly rusted out filler neck.
Comments, suggestions, etc...
Thanks,
Matt
Thanks,
Matt
