I have been using a gravity feed system for over a year with no problems. I used the check valve that Northern sells to put in the oem fill hose. You do need to make sure that your oem fuel cap seals well and that your vent hose on the oem tank is not open to the atmospher. I routed fuel line of the two oem vents to a tee to get to a single line that is routed back to the top of the aux tank. I used a tee at the top of the aux tank to continue the vent line about 12 inches above the aux tank. My capper top has side windows that flip up so I fill my aux tank via the window opening. The height of the 80 gal tank is just below the pickup's side rail so I use a peice of plywood to make a shelve that covers the tank top. I made a round cut out for the aux tank fill cap and a cut out to be able to reach the shut off valve for the aux tank. This high and dry shelve is handy for anything from suitcases to smaller tool boxes.
I chose not to use any aux filters as I look at the aux tank as a big fuel can filling my oem tank and the oem tank has a filter. If I ever add an aftermarket fuel filter it would be placed between the the oem tank and the pump.
I find that the added 80 gal tank is both a money saver and a feel good add on. Last week I was coming back from Ann Arbor and stopped at a Flying J near Saginaw to fill up at 3. 289. Our best price in Petoskey was and is at 3. 459. It is also nice to know that I have 100 gal draw down before I need to start looking for a fueling station.
