Fuel/Water Seperator - How to reach?
Warranty
Vin Numbers
What's the simplest way to reach the control lever on the Fuel/Water Seperator - from the top down, from the bottom up, or through the wheel well? :confused:
If from the top, how can a "catcher" be held under the tubing?
If from the bottom, how do you reach the lever?
If through the wheel well, do you use a stick to operate the lever?
[I've only had this, my first diesel, a week!]
RMcCulloch
Welcome to the TDR, and congrats on your first CTD.
Top down to reach the lever for the fuel filter drain. I went to an auto parts store and got a plastic double male hose adapter and extended my drain line. The first time I drained mine, it puked fuel all over the front diff. Now I put the catch pan on the ground, and it pours right in.
Thanks!
Given the short length of the stock tubing, I hadn't figured a way to (a) hold a container under the tubing and (b) work the lever all at the same time. :-laf
