Template errors
  • Template :: [E_USER_WARNING] Method canViewRmsItems is not callable on the given object (SV\AdvancedBbCodesPack\XF\Entity\User) (src/XF/Template/Templater.php:1277)
Fuel without timing
How do I reduce Turbo whistle?
S&B air filter system
I need a box that will give me the duration without any added timing. Can someone steer me in the right direction? There's gotta be something out there that does this. Thanks
Smarty has programs without timing. I believe it adjusts duration and changes the pressure curve but doesn't increase pressure.
I'm sticking with Diablo for programmer. Just looking for boxes with duration only. Looks like VA might be the only one. Does anyone know if the new TST r49 can run with zero advanced timing?
BD X-Power does this too, basically a VanAaken box. A real P. O. S. in my opinion though EGT's thru the roof with no timing. No service after the sale with BD either. :mad:
Did you have a problem with the x-power?
You could say that, all the sudden no boost fooling capabilities. It wouldnt geo any higher than 30 lbs of boost. I called and they said thats normal. I saw as much as 47 lbs then all the sudden it wouldnt boost fool any more. Threw it in trash and bought Edge, happy now.
Smokin', BD doesn't say anything about boost fooling for the x-power. Also it is not a rebadged VA box. The VA connects to the ecm while to BD connects to the injector harnesses.
I just ordered an VA 3. 2 that will be here tomorrow. I put up a question last week about it, but only got 1 response. I decided that it was my only option because, I didn't want a pressure box, and I didn't want to shell out a small fortune. I think that I should be good to go as long as my cp3 is healthy. I will definitely let you know how it goes. The rep from Van Aaken answered every question that I had and then some, plus I didn't have to sit on hold.
yes the r49 can control timing in 3 degree increments to 18 deg. or it can be turned off. TST is awesome.
The only thing you have to watch for is high egt's with the VA.
Its still JUNK. I still have it if you want it, on my truck for a 1000 miles Ill give it to you for 1 BILL.
