1) the supply frame mounted fuel lines with plastic line connections use a clip assembly at the ends. The o-ring inside is not available seperately from dodge; does anyone have a source?
2) I've heard 16 degrees is the best timing for throttle reponse and fuel mileage on a 215hp P7100 pump, any problems? what tools are required to set delivery valve lift to accuratley set this?
