Archived fuel
  • Thread starter Thread starter jmcintyre
  • Start Date Start Date
Archived Dana Rear End Repair
Archived Did my lift pump die?
J
jmcintyre
Guest
Iam a new owner,purchaced new fuel filter,went to change it it was the wrong one. put old one on but cant get truck started, pardon my ignorance
need help
I will assume we are talkin 24 valve
sounds like you have air in the injector line(s) you mayhave to crack a line or a couple of lines to remove the trapped air.
You can bump the starter to get the lift pump engaged to push fuel
what is your skill level?
See the replies to "Did my lift pump die" on this same forum. It has some suggestions for priming your fuel system.
Good luck.
Loren
