Never thought I would be posting here. We are on our way to Minot for the coming of the second grandson and on the way to Flagstaff the fuel pressure went to zero. I pulled off and changed the fuel filter which looked good to no avail. I then removed the Fleetguard strainer from under the truck and blew air in both directions to no avail. I changed the fuel pump as a last resort to no avail. I finally blew air in the line from the pump to the tank which gave me 12-13psi which gradually went to zero in 10-15 miles. After doing that multiple times we finally made it to Flag. Now this had these symptoms years ago and I dropped the tank and found a vaseline type substance on the in tank strainer which I removed and installed the fleetguard strainer with no problems till now. The problem I have now is I do not think the RV park would take kindly of me dropping the tank so I am looking for alternatives as we still have 1500 miles to go. Came across this stuff, anyone used it ?. Other suggestions ?.
http://www.technol.com/our-products.html#246
I am going to take the truck for a ride on I-40 to try to use up some of the approx. 17 gals. still in the tank and see what the pressures do, may have to stop a few times and blow out the line. What a PIA when you need to be somewhere.
