I purchased a Fumoto oil change valve for my new truck and paid $22. 50 for it. It is basically a brass, lever actuated, ball valve that screws into the bottom of your oil pan replacing the standard drain plug. I had used this plug years ago on a Buick I used to own. It always worked well and never had any problems. The model that I purchased for my new truck was "F104". Some people have claimed that holes or slots have to be cut into the threads of the valve in order for all of the oil to drain out. I don't know if they had the same model and/or type of valve I have or not. Anyway, I let all of the oil drain fom the vehicle via the Fumoto valve. I was curious if I took the valve out if more oil would come out as others had said. I took out the valve and no oil came out. I was on level ground with an absolutely stock 2002 H. O. Cummins. I am not disagreeing with anyone, I'm just stating what my experience was. The threaded area of the valve is shorter than the threaded area of the drain plug and perhaps this is why it drains completely. See photo for comparison.
Fumoto Valve Website
CAUTION: The preceeding post is only MY opinion and a collection of rambling thoughts. Following, emulating, extrapolating, or thinking about any part of my post could cause world anihilation and extiction of spotted owls and/or other endangered species. Reading of my posts have also been known to make babies born naked. EXTREME CAUTION URGED!
