A business, any business, invests capital and labor in order to provide good products and/or service and earn a fair return on their investment. It is called capitalism, the basis for the greatness of America and the stength of our economy. Any business who doesn't won't be around long.
Harvey
Chinamen tires should start making tires with respect to an AK47. They had good luck with them things.
CUMMINZ
having four flatbed trailers and a cargo on the road making a living [36' tripple GN down to a 14' cargo] putting up truck stop driveway covers several years ago, had us carring two spares for each trailer. A goodyear truck tire dealer showed me there were much better tires for our trailers than a ST tire. This was a long time before Chineese tires. He set me up with radial LT tires on all my trailers that had ST tires and no more shredded tires on every trip. I don't/won't use ST rated tires even on a wheelbarrow and would not give anyone a recommendation of even using a ST rated tire.
A ST tire is what it is and it ain't much. Goodyear Marathon ST web had a couple of differences in ST tire construction. They have only 9/32 tread depth vs some LT tires 17/32 tread depth. They also have a narrow tread design that leaves a basketball shaped sidewall. Anyone that has pulled trailers much for a living knows a basketball shaped sidewall doesn't make a good trailer tire. With that sidewall bulging outside the tread it is much more suspect to sidewall damage/cuts. AND that basketball sidewall allows much more sidewall flexing which generates heat. We know what heat does to a tire. The Marathon web said they are "very ecnomical". They are fed mandated to 65 mph max and not recommeded for passenger vehicle use. That outa' tell us something.
For a fact per email and a phone call to Michelin customer service to "Bobbie" for confirmation that Michelin still recommends the XPS Rib LT tires for commercial trailer tire use [as per their old web add]. Other LTs that are recommended by their manufactors for heavy trailers are the 16" B F Goodrich Commercial LT E and 16" Uniroyal Lerado HD-H LT E tires. For 15" tires I use a LT that will fit.
Both of my "single axle" trailers [13"/15" tires] have P rated tires with plenty of capacity and speed rated for running 75 mph legal speeds here in OK.
I'm sure glad a Goodyear truck tire dealer recommend me LT tires years ago. I just don't have ST tire problems anymore.
JIM
JIM
[snip]
I mounted the new set myself, and can tell you that the Marathon ST has alot more weight to it then a comparable 225 75R15 truck tire. Thats just my . 02
I must be the exception to the rule on ST tire. My 2000 Maclander 12k trailer was delivered to me brand new with ST 225/75R15 tires, and I just replaced them for the first time in its life, last week. The tires probably had 50,000 miles on them. Tons of 75-85mph highway runs for 10-15hrs nonstop with 8-10k of load on them. Never had a blowout, flat, leak or anything else to speak of. The tread was starting to get low, and they were beginning to get some cracks in them so I decided to replace them. I must have gotten the only set of Goodyear Marathons that were any good. I mounted the new set myself, and can tell you that the Marathon ST has alot more weight to it then a comparable 225 75R15 truck tire. Thats just my . 02
