I am doing this swap into a first gen soon, as I bought a G56 yesterday. . being shipped to me now... its a '07 zeromile take out from a 6. 7 L 4x4 so it should have the AE gearing with the . 74 OD. .
I'm trying to figure out a few details :
- The nv4500 engine to trans adapter ... . is that what you used with the G56
in you swap? or did you need the 3rd gen adapter?.
- The Starter... . did you have to buy a 3rd gen starter? I may have to as
the first gen and second gen starters are different.
- The clutch disk ... ... . what disk did you use? as the G56, I was told has a
1 3/8 input shaft that is longer then a nv4500 or nv5600.
I have a 13" flywheel with ballbearing and con fe new kit at home for a
5 pd Getrag. I am, crossing my fingers to be able to use that and just
change the fe disk to a 1 3/8" FE disk, and buy the upgraded hydraulics.
Any Thoughts???
- The trans output spline is 29 splines correct with the round 6 bolt pattern
to mount the transfercase correct? I have a different transfercase then
the 2nd gens. I hope it mounts a np 205 without to much hassle. I plan
on twin sticking my np 205 while I have the chance.
Thanks, if you can help on any of these points it would be appreciated. I plan on documenting the conversion on firstgen sections. I started a thread there too. also I plan on mounting a Chelsea 442 series pto on the trans too . . if any of the 2nd gen swapo guys are interested in doing that. I'll be documenting that at the same time.
Thanks
Deo
