GJ is a gimmick, the G56 has several different metals, even to a point that several ground straps need to be installed to prevent electrolysis on the the gears, pitting them. There are much better options than GJ. It's a possibility that your trans is running hot, that will allow the aluminum to stretch and cause the gears to run out of alignment, CKelley1, has a good formula with high mileage on several G56's towing heavy, I recommend you send him a PM, before you waist your money on GJ.
