Lektrikman said:Steved, Can you tell me, was there a recall for low fluid in the G56 trans? I've got an 05 with a G56 that I just changed fluid in and filled to the bottom of the fill hole per the factory service manual. If there was a recall, do you remember the number? Thanks, Lektrikman
Doughboy21kd said:i went through this a couple days ago..... Fill too the fill hole... . then you nedd to add one more quart, either through the shifter in the cab which coud be a pain, or there is a another plug lookin but its more like a long bolt on the driver side right above the slave cylinder and it is a Torx head the size is T-60... . take it out and add in your additional quart there... . I just did mine yesterday... . Hope that helps... . BTW i got this info straight from the dealer
