GAmes
I'm in the process of installing a G56 out of an '06 into my '97. I've read the TDR article on the transmission and understand that it takes 6 qts of ATF+4. Since the shift tower is off now pouring it into the top is easy. Is that the only way to get the full 6 quarts in. I have read the fill port is at the 4 qt level and the plug above it should not be removed.
Also, what is this plug for? I'm guessing the backup lights.
One more. There is a tube next to the shifter. Is it for the vent and should there be a rubber tube hooked to it?
