photowrite
So I want the most hp and tq from the factory with the G56.
So reading these posts the auto with the torque management only allows full torque at the right time under perfect conditions?
The G56 has full torque control with the go pedal?
Are there any dyno runs sheets or specs that show when the torque kicks in?
Thank you Casey
With your experience, I bet with a back-to-back test drive you would be able to feel how much or little difference there is between the G56 and an A/T and the perceived power.
One of the things I like about a turbo, manual trans... Is even though momentum is lost when changing gears, losing rpm, and boost, when all comes back up after you tip back into the accelerator, the full-surge and 100% lock-up of a manual really makes the twist noticeable... true on the my new Ram, old Ford, and our VW TDI.
Besides the torque mgmt, I'm guessing the EB works better with the G56 as well. I've been reading the the EB doesn't work under 20 mph on the auto transmission. That would irritate me as I was always using the EB on my 04.5 at slow speeds.
Yes!
I've been impressed with the factory exhaust brake... Works down to about 900 rpm regardless of road speed or the gear selected.
