The truck is a '05 H. O. The tank was accidently filled with gasoline on a return trip home.
After about 40 miles on the freeway, the truck started running rough, so the owner pulled over to the shoulder, before backing up to a off ramp. The truck was parked and is now in the process of being towed home. Other than the obvious drain the tank, lines and replace the fuel filter, how does one go about draining the CP3 pump? The tank was down when fueled, so is there damage that could occur to the CP3 pump and injectors? Thanks for any help!
