Gauge Issue
Which Front Drive Shaft?
Options for steering box replacement
Gauge Issue
Something new started with the truck about a week ago and it does it when the truck is moving or parked. All of the gauges except the tach and speedo or the ones I installed... ie fuel volt oil temp stop workin for a second or less. Sometimes it's just the fuel gauge itself. It's like the cluster loses signal or power? But the tach and speedo are fine? I dunno, any input?
Isn't there a way to test the cluster? IIRC, hold the reset button in the cluster faceplate and turn the key to the run position. Everything kind of goes nuts with the gauges and then it displays codes. Somewher on this site is a post with the codes. Could I be anymore vague???? I read the post and did the test once. Sorry Red, I hope this helps you somewhat.
Dave
What year is the truck? Sounds like an instrument cluster problem, perhaps in the front control module.
Ryan
