Gauge Lights
swap my 5 speed for an auto transmission!!??
silincer ring??
I tried to do a search and no luck. I pulled the light switch and gauge dimmer switch out and still don't know where to tie in my gauge set light . I want them to come on when I turn on my headlights and also be able to dim them as my insturment s lights do
Thanks
Nathan
You can pick up 12v from fuse number 5 in the dash fuse panel. It operates the dash lights on my '99. Just use one of those little clips that go on the fuse blade. I upped the fuse value from 5amps to 7. 5amps when I added the additional lights. They will work with the dash dimmer.
Denny
'99 2500 4X4 White short Q cab to much added to put here
Well that didn't work. . try to search Lordsman on 3-15-00 under the title "12v Inition Source" I know Ignition is spelled wrong, but thats the way it is in the title.
Ron
'96 4x2 2500 Garnet/Driftwood Auto,3. 54,K&N,Cobra,Westac guages combo 50psi boost/egt, trans temp. on AutoMeter full piller duel pod, 93 TT Terry 29L,'84 VW Rabbit diesel,
I just used a scotch-lok connector and tapped into the dashboard lighting. It should be an orange wire...
98. 5 2500, 24v, QC, 4x4, 4. 10 LSD, short bed, Line-X liner, tow package, camper suspension, Westin nerfs, camper shell, TST PowerMax3, 275 RVs, ProComp A/T 305/70/R16s, EGT/Boost pillar gauges... Love my Cummins, no love for Dodge
Sorry about the typo. I'm no typist.
Get to the back of your light switch and (if you know how to use a meter)locate the tan wire. Turn lights on and check voltage. Should be anywhere from 4. 5 volts to 12 volts depending on the dimmer setting. Verify on and off as well. Attatch your lead wire with tap-in squeeze connector (18-22 gauge) available at Radio Shack. You must also use 18-22 gauge wire here. I used 18 gauge thermostat wire. Enjoy.
Added mine when I did the headlight switch update. Added an extra wire to the new HD pigtail.
'94 3500 4x4, 209,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro Gauges & Amsoil Air, Oil & Bypass Filters & Lubes, AWOL intake boot.
Punchlist: X-Mount Mirrors, 14 cm Turbo Housing & 215 Injectors.
NRA member.
Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
