Gauge pillar mount............
350 Marker/Body Lights (For dually fenders and tailgate)
Rear End ring and Pinion needed, 1989 4WD
Anybody know where I can get a three(3) gauge pillar mount for my '92?
I've seen two(2) gauge mounts at Geno's but not three(3).
The only one I have seen is a ProParts mount that doesn't look like you could read the gauges from the angle of the holding pods on the mount.
Any body have any experience with ProParts mounts?
Also looking for a 14cm2 turbo.
Thanks in advance for any help... ... .....
Billy
Found............
O. K. I found a three gauge mount at "Auto Zone" of all places. It is made by Sunpro and I'm in the process of mounting it in the truck. It took a little "messaging" with some pliers and a heat gun but I think I got it to fit pretty well.
Also I going to go with a 12cm2 turbo instead of the 14cm2 and I'll see if that works and doesn't raise my temps to high on the top. If so, then I probably upgrade the compressor to a 60mm.
Billy:cool:
Pillar mount/dash mount
I don't have any part numbers but the "maker" is SUNPRO" and it is available through Auto Zone. It could be at a little more of an angle (for better viewing) but it will do for me... ... ... ... .
The steering column mount is for the tach. . I put a "sleeve" behind the bezal so the guage would look like it fit the mount. It stuck out because of the light so I just added the sleeve and know it looks like it is supposed to be that way.
Billy
Sorry I couldn't rotate them prior to posting... ... ... :{
Thanks, pillar mount looks like it still needs a little "massaging" there at the top..... or is that the way it came?
pillar mount
That's the way it came... ... ... ... Generic fit, not made for any specific pillar. That is what I'm trying to figure out next, How to make it look better/blend it to original pillar. Something... ... .....
I painted it (it came black) but still need to "fix" the upper end.
Billy:cool:
For the piller pod I used an Auto Meter, two hole pod with another Auto Meter Single pod on top of it.
