Just helped put a set of Autometer Phantom series gauges on my buddies 01. We tapped into the "alum" fuse for the lights so they could be controlled by the dimmer. We went for a test drive and the dimmer switch area was getting warm to the touch and the dome light would come on almost as soon as you would try to brighten the dash lights up with the knob. The only time the gauges were lit up enough to really see them good was when the dimmer knob was up high but then the dome light kept coming on even though it was not in the dome light position. Is there a better fuse to tap into rather than this one? What else might be the problem. This was my first gauge install so treat my like the dummy I am! :-laf
