Gauge questions for 2007.5 6.7
'03-'05 Aftermarket Headlight Replacements Found!!
Deka Battery ??
Looking to put in some aftermarket gauges. Saw the add for Diesel Manor's setup ISSPRO 3 gauge and 2 gauge units. What boost pressure range are the new 6. 7 motors running? Anyone installed a set and have any suggestions. I thought the 3 gauge set would be best so I could include the transmission temp.
thanks in advance.
Wayne
I ordered the three guage set from diesel manor. ISSPRO pyro, 60lb boost and trans temp. Max boost I have saw is about 32lbs. I told them ten times my setup was for a 6. 7ltr and they sent everything for a 5. 9ltr. It all worked but the trans temp. My installer talked with them and they sent a part to tie into the hot line on the trans. works great. Everything is much tougher to do according to my installer.
2Rowdy, thanks for the reply. I found your own post about the gauge install after I made my post. I thought the install was a little harder than their ad makes it seem. I'm checking around locally to find someone in the Alb area that can do the install and how much they'll charge. I didn't think that a 30lbs boosts gauge would work either and that seems to be their default size.
