Gauge Rattle
Interior Lights Wont Light
Firestone Transforce A/T 235/80-17's
Under load my Isspro boost guage rattles. Any fixes or ideas what that is?
I am using the boost bolt for my pressure reading.
Mine does it every so often, usually the post mount screw is loose. I tighten it and the rattle goes away until the next time.
It's normal - pressure pulsations in the line. Kind of like water hammer, but on a tiny scale.
If it really bothers you, you can put a snubber in the line (Geno's carries them). The noise won't harm anything.
Ryan
Thanks!!
It looks like your both right, I tightened everything up and it elimininated 90% of the rattle and what is left (which is not very much) I will see if I can live with before putting the snubber in.
Thanks so much.
Barry
Any gauge seeing pulsations that cause an audible sound is being slowly beaten to death internally. Get a snubber.
If anyone is experiencing boost gauge rattle with an ISSPRO gauge - if you are interested in testing a possible fix, please PM me or email me (michael@isspro.com).
Thanks and regards,
Michael Pliska
Truth be told, I actually like the rattle. It's an audible signal that I'm gaining boost rapidly.
Ryan
Ill admit that I was learning to use the rattle as some what of an audile signal as well. It works like a vertical speed indicator in an airplane to some degree. The rattle was there when you are rapidly building boost, but stops when your rate of change drops.
JT
