Gauge Sending Unit Questions
what's the fix for the cold weather power steering howl?
mystery switch
I’ve just ordered 2 SPA gauges from DIS, an EGT/Boost gauge and a Fuel Pressure/Water Temp. gauge. Before I go any further I have to tell you the service from DIS was amazingly quick. I ordered them yesterday, one was out of stock so they said they would see if it could be drop-shipped to me. Today the UPS guy showed up with both gauges, and I didn’t pay for overnight shipping!
On with the questions:
From previous posts it appears that I need to get a –4AN to 1/8 NPT adapter for the fuel pressure sending unit if I’m going to attach it to one of the Schrader valve fittings. Is this correct?
The main question I have is where to install the water temperature sending unit. There are a lot of plugs in the block, but I don’t know if they go to water, oil or other passages. Any help here would be greatly appreciated.
Thanks
2001. 5 Intense Blue 2500 QC, SLT, 5. 9L 24v Cummins, 4x2 Auto, 3. 54/LSD, 155 inch WB, Agate, Trailer Tow Group, Sliding Rear Window, Line-X over the rail, Leer Cab Height Topper.
I'm interested in the fitting size too. I will be ordering an electric Autometer fuel pressure gauge. The mechanical one I got will not fit in the pillar mount.
This is a great site for all kinds of info...
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
I believe the correct size is -6AN to 1/8". Check out Brandon's site below for all the info you will need. I also have a SPA, but purchased the Schrader to SPA adapter from him and I'm unsure of the size.
I can tell you that the plug you want to use for the water temp is at the rear of the block, driverside, behind the map sensor. Be warned, when you remove that plug, I think it's a 3/8 drive, you will loose coolant, so be prepared to either drain the system or have your new SPA adapter ready to go a. s. a. p.
Scott W.
Brandon's site
Goodrich makes a 4an x 1/8npt adapter that can be used. the spa's must be mounted pre filter. I have two adaptors that i have made that offer the flexibility to mount the pressure sensor in any direction.
Brandon
Danelle's Dodge
Brandon
Brandon, Hey there,
Does the adapters still allow the use of the schrader valve for testing?
<font color=forestgreen>2000</font> DODGE <font color=forestgreen>RAM</font>, <font color=forestgreen>2500 HD</font>, 4x4 SLT, Reg. Cab, <font color=forestgreen>Forest Green</font>, Agate interior, Cummins ISB, Auto, Shift-on-the-Fly (241HD), 4. 10 LS, ABS, Trailer Tow Group, Camper Group, Michelin; DC: Fog Lights Kit, Tow Rings, Under Rail Bedliner, VentVisors, Splash Guards, Cold Weather Cover, & Mats.
<font color=forestgreen>After-market</font>: JRE 4" Exhaust, Van Aaken, High Idler, Heavy Duty Idler Pulley, Gatorback Belt, Painless Wiring, K40, Viper w/AutoStart, Clarion 6 Disk CD w/remote, UnidenCB w/Francis antenna, Draw-Tite Activator II, Alpex 255TC2C Air Horns, Continental BedRails, Delo 400, HOWES, Liquid Glass.
BigDaddy's Ram #ad
New England RamRiggers
<font color=36648B>2001 PT Cruiser Limited Edition</font>
is the 1/8" NPT male or female on the
goodrich part?
Charles
My Toy
BigDaddy, you have to remove the Schrader valve for the SPA adapter to work. Sorry I was wrong on the size, gentlemen. As always, still learning.
Scott W.
Bigsaint,
Thanks #ad
Has anyone tried a union and "T" fitting for prefilter? I am only going by memory (boy, that’s scary #ad
), but seems that there is more than enough room.
[This message has been edited by BigDaddy (edited 04-21-2001). ]
