gauge wiring help needed ASAP
How to install putnam class v hitch?
aircondition
Hey guys,
I have my truck apart in the driveway putting in the gauges I got for Christmas!! I am working on wiring the gauge lights. I pulled the headlight switch panel off to tap into the dimming circuit and much to my dismay I couldn't find a orange wire with a white tracer as suggested in numerous threads. I have an 04. 5' with fog lights. Would it use a different colored wire? Thanks.
Chris
gsbrockman said:
The "search" feature & test light are your two best friends..... especially the test light.
Greg
Greg, I did "search" and read many posts as stated in the "as suggested in numerous threads" part of my post. Like I said, all I found was orange with white tracer answers.
Thanks jawmail, I'll try that.
The last set of gauges that I did tapped the dimming wire into the light at the ash tray. It is only a slightly longer wire run, but a lot easier to access.
I hit the constant 12V at the power outlet (or lighter element wire- forget which. ) Again, a slightly longer run, but easier to hit.
Connector pinout
I have attached the headlamp switch pinout from my 04 shop manual. The pins are the same just color of wires changed from model year to model year.
