Had this problem for a little while now I need to get it fixed, emissions test coming due and they will not test with cel on.
Started my truck one morning and 30 sec. s later the chime goes off and my gauges all went to 0. 0. I've checked everthing from all the other threads and even put die elec. grease on the gauge pins. I did a self test on the gauges and they check out fine. cleaned all the grounds I could find, checked the plugs on the ecm and pcm and checked fuses in pdb under the hood all ok. If I can't get this fixed I guess I'll take out a second mortgage and take it to the dealer. Truck runs great and the only thing that doesn't work are the gauges. Could the ecm be bad? pullin out the hair now.
Jim G
Jim G
