Gauges for my 40.5
What's the general lifespan of shock absorbers?
A/C air flow drops off
I have Isspro 30 psi gauge and it does peg under full throttle for a few seconds then comes down to about 25 (I guess when the wastegate opens?)
I know the kind of gauges but dont know how much boost on stock motor what gauge would be best 35 or 65 ?:confused:
I run a Westach dual gauge on my 06... . The boost side ranges up to 35 psi which is perfect for a stock engine. If you dead stop floor it, you can hit approx. 34-35 psi for a split second, then it backs off to 32 psi.
If you have no plans on going beyond stock, I would stay with the 35 psi gauge, it will give you more accurate readings vs. a 65 psi gauge.
