True to a point. . yes it will slowly decline in its volume. . Most people report their pumps pressure get really eractic before they die. . others just a slow decline until they are dead. . If the pump is not putting out its full volume, you could have problems.
I'm going to use some hydraulic pump figures, but the same applies. . If the lift pump puts out 6 Gallons per Min. (GPM) and the main pump only needs 3 GPM all is OK. . but now we have a big load and the main pump needs 8GPM. . but the LP is only supplying 6. . We have a problem. . Cavataion. . a miss, stumble. . We are watchin the pressure between the two pumps...
Just hope to catch it before it is completely dead. .
(I'm also 99% sure it was the VP44 pump- that is lubricated and cooled by fuel. . no fuel or cavitating fuel, is hard on a pump like that. (I've to so much on different fuel systems, I cann't keep them a part, but I see no oil lines on the VP44, so that must be it. . )
Bryan
