Finally got my gauges installed. What a PITA!
Way too many wires, but it seems as if the Dodge would be a good truck to do it on since everything is pretty accessible. I think it was worth it though. Well, it took me two days worth, not full days but two interrupted afternoons.
I went with the Isspro Marines, 0-60 Boost and 0-1500* EGT (Pre-Turbo), and a two gauge pillar-mount pod, all from Geno's. I must say excellent support from Geno's. Definately on my future vendor list if need be.
So I took it out tonight after everything was installed. I like the looks of them better during the day (besides the little glare which is acceptable), but they aren't at anyway hard to read at night. They are very responsive and detailed.
The readings were:
Idle(Engine Fully Warmed):
-400* EGT
-3 PSI Boost
j/k
0 PSI Boost
1750 RPM/60 MPH/Engine Warm/Fairly Flat Land:
-700* EGT
-3 PSI Boost
Foot To The Floor/Engine Warm/Varying Land:
-1100* EGT Max
-32 PSI Boost Max
Well does this show that I didn't need gauges that bad, or is it unique? Only mods are a TST PowerKit with #6 Plate and a K&N drop-in filter. Still glad I got the gauges.
From these readings, is their any free upgrades from the pump or turbo, or what is next?
Thanks,
Trever
The readings were:
-400* EGT
-3 PSI Boost
-700* EGT
-3 PSI Boost
-1100* EGT Max
-32 PSI Boost Max
Thanks,
Trever
