Gauges
turbo rebuild
OK,Transfer Flow vs Aero...ANY differences???
I am ready to order a set of auto-meter gauges but undecided between the sport comp and Z series. I am leaning towards the Z series, only because they offer a boost gauge that is 0-60 psi. Then again, does that make any difference or is 0-30 psi ok? Who else has these gauges and are you happy with them? Appreciate all comments.
Thanks
Bill
Autometer makes a 0-35 and a 0-60 psi boost gauge in Sport Comp, Ultra-Lite, Carbon Fiber and Phantom series gauges, not just the "Z" series which by the way is considered there "Budget" line. Call Autometer direct at 815-895-8141 and ask for specific part numbers. Or call www.jannettyracing.com, they stock most of those gauges.
Forgot to mention. If your truck is mostly stock the 0-35 PSI is fine. I have a 4" exhaust and the Psychotty kit and i never go over 20PSI on my 0-35psi Sport Comp boost gauge. I know the aftermarket performance "boxes" raise the boost levels, but i dont know how high with which box so ill let some other TDR members answer that question.
I just found out summit raceing blows everyone away in price for the Autometers.
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Exhaust, Bosch 275 Injectors, K&N, 33" BFG AT'S... ... .....
If you're going to leave your truck bone stock,then the 30psi is just fine. *BUT* If you want to add some modification down the road,then the 30psi gauge is going to be useless to you. No sense in spending money twice eventually.
-Mike
I agree with MikeR. UnBOMBed and planning to stay that way, 30 psi's will be about 10 more than you need. BOMBed is a different story. My DiPricol boost gauge goes to 60, a little bit of overkill as I never go above 40 psi's at WOT (and don't want to !!!). 40 psi's in my truck means I'm in warp drive, and EVERYTIME I see that number I cross alot of body parts while praying that the HX40 doesn't do a bad Elvis immpersonation and then die.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Ditto on Summits pricing. A word of advice, know your part numbers before calling Summit. Call Autometer direct at 815-895-8141 and talk to them about EXACTLY what you want (Style, Bezel finish, range, etc) THEN call Summit and order. Also, the boost gauge i have is 0-35PSI, not 0-30. The only boost gauges i have seen in Autometers Sport Comp, Ultra-lite, Phantom and Carbon fiber series are 0-20PSI, 0-35PSI and 0-60PSI.
<font color=blue>There is a 0 to 50 PSI available too. Its a custom gauge tho so you won't find it in any catalog. Heres a picture of just the gauge.....
You can get this from JRE, Ted graciously helped out when this gauge was built for a few of us (including himself).
[This message has been edited by KatDiesel (Eric Howard) (edited 04-26-2001). ]
Forgot about the 50PSI. I got my 0-35PSI Sport Comp boost gauge from Jannetty also. Ted is a great guy, knows his stuff. Will definatley be buying from him in the future.
