There is a dash mount option if you do not have the heated seats, Quadzilla sells a aluminum plate with either two or three holes punched in it for that fits in the cubby hole. You remove the cubby hole, remove the rubber liner from the cubby hole, and the plate gets sandwiched between the cubby hole and the front plate. There is a hole in the back of the cubby that all the wires and capillary tube can fit through, so nothing has to be modifiied if you ever wanted to remove it and put it back to stock. I took a couple pictures of the guages, not very good ones, they are in my reader rig album.
