CTRice, I sure don't know if a fuel pressure gauge is necessary but I have more than one person tell me if I am only getting one gauge to get a fuel pressure gauge. I don't tow a lot of weight and I have no mods. The SRT-10 pillar looks real nice but that real estate is already used up on yours. I am a little concerned that I may end up with more than one gauge so I am thinking about putting the fuel pressure gauge over the mirror on the windsheild. I think I am going to get an Autometer, unless I get bad feedback from people, because it uses a sending unit and won't run fuel or whatever fluid they use for an isolator into the truck. The top of the dash looks like another good place to put gauges so i might need to flip a coin. It sure seems like the column mount would be in the way of the CEL and other lights at the bottom of the dash display. I am thinking about the Autometer for two reasons. It is more expensive than the Westach, so it has to be better, right? And the sweep on the Autometer is wider. The Westach looks to have about a 90 degree sweep and the Autometer looks to be about 270 or so. The only reason that matters to me is if I need to get an external lift pump. The Westach looks like it would be fine if I picked the 0-15, but it would not handle the 20-25 of a new lift pump. If I got the 0-30 Westach it does not look like the 90 degree sweep would provide enough resloution to see the difference between 8psi and 5psi. Anyway, those are the thoughts of someone that knows nothing. Oh yeah, I'm just going to use the T that comes with the GDP kit to tap off of. I sure hope someone tells me if I am going down the wrong path with this stuff.
