Here are the numbers on the gear lube analysis. Miles on lube - 38K of which approximately 30% was towing. Lube was Amsoil Series 2000 75W-90. First number is my oil, second number is universal average
Aluminum 1 2
Chromium 7 3
Iron 278 514
Copper 2 2
Lead 0 0
Tin 0 0
Moly B 0 3
Nickel 1 3
Manganese 8 12
Silver 0 0
Titanium 0 0
Vanadium 0 0
Boron 75 141
Silicon 93 152
Sodium 8 8
Calcium 7 19
Magnesium 1 2
Phosphorus 1086 1411
Zinc 40 57
Barium 1 3
SUS Viscosity @ 210 deg. F
should be 67-80 was 73. 4
Flashpoint should be >375 Was 380
Water should be <0. 05 Was 0. 0
Insolubles should be <0. 6 Was 0. 4
"Comments: Wear and silicon read at about half the universal average levels for a lube oil from this type differential. The iron wear looks okay but we would rather see the silicon down at around 50 ppm or lower. If we didn't know better we would think this was OE fill. Insolubles and the viscosity of this lube oil were normal and we found no moisture in the sample. Suggest changing this lube oil to limit abrasion for the next use cycle. "
The silicon levels may be easy to explain. I had two bad pinion seals during the run on this lube. I had no makeup oil at anytime prior to the analysis. Last weekend I dumped the lube and filled it up with Amsoil Series 2000 75W-140. After reading this, it turned out to be a good call.
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Rancho 9000's on order, PowerEdge EZ Box, Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
[This message has been edited by John Berger (edited 05-17-2001). ]
Aluminum 1 2
Chromium 7 3
Iron 278 514
Copper 2 2
Lead 0 0
Tin 0 0
Moly B 0 3
Nickel 1 3
Manganese 8 12
Silver 0 0
Titanium 0 0
Vanadium 0 0
Boron 75 141
Silicon 93 152
Sodium 8 8
Calcium 7 19
Magnesium 1 2
Zinc 40 57
Barium 1 3
