I'm in a '19 Ram 3500, Aisin, HO, and I was just looking over my owners manual for fluid changes.
The line that reads " inspect the front and rear axle surfaces", only says to change the fluid if used for police, taxi, etc, but no mention of mileage interval if its used as an interceptor or a grocery getter. Literally the whole box is blank of the Xs marked at intervals for various other categories.
I've had it in my head that it was due at 30K, but nowhere does it say how often.
I just crossed 30K miles.
What brand oils/ weights are folks using? I've just learned about the little squeezable packets of amsoil gear lube, that seem handy, but I am just seeing these in 75W90, and Ram says 75W85 front, and 75-w140 for the rear.
The manual seems very poorly laid out, and I don't see anywhere that lists the fluid quantities for anything.
And for the transmission, are you dropping the pan, or just draining it? I read to catch what you drain and add that same amount. How much of this should I buy, and what flavor of this fluid do you guys like?
Thanks,
Dave
Thanks,
Dave
