3.73 is an option, and would probably be the perfect gear for most of us. I will only buy Spicer or Yukon gears for the Danas. I would not try the Spicer SVLs (Spicer Value Line). Randy's Ring and Pinion is popular, or you may find used on Ebay. New gears for a Dana 80 was somewhere around $800. I would look for someone, close to you, who wants 4.10's and swap axles. Just curious, what are you trying to gain? A bump in your timing and RPM governor, if you haven't done so, should make a big difference.
