Ozymandias
No they don't.
Hi, we had our transmission rebuilt by Inglewood transmission in Fullerton CA. They found that the converter clutch was burnt, the front pump was damaged, second gear band was burnt and several other components. They replaced all the components with upgraded Goerend billet input shaft Goerend clutches and bands and a Goerend converter. Picked up the truck and the shift quality is nice, I am looking forward to our next RV trip. Thanks again for your input Gil
I have a question about rear differential gear ratios. I have a 2001 Dodge 2500 with a 24 valve Cummins engine and 47RE transmission. I tow a 12000 lb fifth wheel trailer. Our truck has 90000 miles on it mainly towing. I had the rear differential gears changed from 3:73 to 4:56 gear ratio for better grade climbing. Our truck is stock with stock size tires and it’s a 2 wheel drive model. I have been told that the low gear ratio is not good for the transmission or the engine, I do keep rpm’s below 2000 rpm when possible, sometime on heavy grades I need to down shift to lower gear and rpm’s go above 2500 rpm’s. The transmission is having some issues and the transmission shop recommended that I go back to the stock gear set. Any information would greatly appreciate. Thanks Gil
