Engine/Transmission (1998.5 - 2002) Gear swap in So. Cal>?
Engine/Transmission (1998.5 - 2002) Turbo elbow larger?
2nd Gen Non-Engine/Transmission swapping dash from 98 into my 95?
Is anyone interested in a gear swap? I have 3. 55's and want to go to 4. 10's. I bought a big 5th wheel and want more low end. It's a 4x4. I'm working with a local shop right now, but it just seems easier to swap axles. Any takers? May not cost you anything. :--)
Nickaru, it looks like by your signature that you have the perfect tow truck. Why would you want to change to 4. 10's? I don't think you will like them running empty. Keep in mind that 4. 10's in 6th, will be like 3. 55's in 5th. Sorry, I know it is none of my business, I just had to vent!!
"NICK"
I hear ya about the 4. 10's. I had a 2001. 5 two wheel drive and it had the 4. 10 and seemed to run out of gears on the freeway but I never towed with it and it could have used the 3. 55's. My current truck is a freeway flyer and I wnet from a 21 foot toy hauler to a BIG 5th wheel trailer two weeks ago. The truck hops bad at times trying to take off from a stop. It does have the metallic clutch and I know that's it's nature, but I think the lower gears should minimize it. Also, according to Dodge's towing guide, with 4. 10 gears your max trailer weight is higher. My truck is a weekender and isn't a daily commuter. It gets to stay in my shop right next to my new Next Level Toy Trailer. :D
Currently, I run 5th gear to stay at the 55 MPH speed with the trailer. Last time I used 6th gear towing my little trailer, it cost me $400 :eek: :{ from the CHP clocking me doing 69 MPH. That's the sweet spot for her in 6th but not with a trailer.
I have about 56,000 miles on the truck and I use Lubrication Specialists gear oil. I can't remember the name, I have it at home. I'll post it when I get home.
Hi Nikaru I also live in Lancaster and might be interested in the gear swap any chance we could get together, I'm at L1 and 23rd west. 478-9626 Rob
Gears
Nickaru, I'd be real interested in what you think after the gear change. I have been thinking about going to 4. 10s also. I bought a big 5er and tow the boat behind it. I'm at about 21k lbs total and although I don't have any trouble getting it moving, I thought the new gears would be nice for the hills. Although NIsaacs point is a valid one. BTW, I also live in Lancaster. See you on the road.
Hey guys. I have a 99 with 3. 54s and an ATS trans. I pulled a 36' triple slide. dry wt. 12600 lbs. and with the comp box on the #3 setting had no problem doing 50 up the grapevine. I also live in Palmdale,(next to Lancaster). We need to meet you folks. There is a big group of Dodge Cummins owners here in the AV. How about coming out to the next DHRA drag races at LACR on July 16th. I will be there racing and so will a bunch of us including Rhancock (post #6) who is a friend of mine too. Check out www.LACR.net for times. Would love to meet you guys. Betty
Nickaru said:
I'm going to pencil in that date on my calendar for the DHRA races. Looking forward to it!
Great. . Will see you there. Did you get ahold of Rob about the gear swap? Just wondering how that will work for both of you. :D
In the shop
I just put it in the shop Monday for new 4. 10 gears and posi's front and rear. I waited and didn't get much on replies. Sorry. I'll have the 3. 55 gears and limited slip for sale shortly. Only 50k miles on them. :D
What's it going to run you $$$ for the swap? I'm thinking of doing the same thing 3. 54 to 4. 10. I have a 2wd so just the $$ for the rear end.
Bob Weis
