If you have a factory overdrive transmission and a 4. 30, 4. 10, 3. 73, or 3. 54 rear and are thinking the Gear Vendors will get you better mileage when towing - we would not agree. It is false economy to think you can tow a heavy load with just 1/2 an engine revolution per tire turn. Staying at 50mph and below are the best ways to save fuel and wear on your truck because the aero load of the typical trailer is 1/2 at 60 what is at 75mph. Factory overdrive + Gear Vendors is perfect for when the truck is not towing, but when you are towing the aerodynamics require horsepower. The UNDER/OVERDRIVE™ can be extremely beneficial and capable of delivering hundreds of thousands of miles within these limits
