Got one for my '96 with 5 speed. (needed to split 3rd and 4th) The Automatic transmission is a better application. With a manual, you must disengage the GV while transmission is in neutral, since mine would drop out with a not so subtle clunk once the clutch is engaged. A lot of shifting occurs while going through the gears. Upshifting is really fast and easy however. Probably more useful with the 410 axle . An Exhaust Brake will kill the GV unit since it's not designed to have reverse thrust. While I had the mine, I enjoyed the quick upshift in 3rd and 4th. 5th over was too much for my 354 gears, and 4th over was very similar to 5th straight, but didn't challenge the 5th gear retainer nut. At the time I dyno'd at 527Hp, and the think held together. Greg
